I got this 2001 SLK320 that had a brake light warning showing on the cluster so I found out the driver side rear brake light was out so i switched out the old bulb for a new one but the light still wont turn on and the brake warning icon on the cluster is still on. I checked for any recalls for the car and there was one for the brake lights back in 2006 and it seems like a common complaint on the recall site too. Does anyone know any possible issues?
Handy to learn soldering skills with the R170. We ended up replacing the unit.
They are old cars and from what I've read on this site soldering can be an issue.
It's also worth checking whether the sponge around the pse pump in the boot is wet/damp.
It'll save you time and bother in the future if you check it now.
Gummi pflegging and greasing is also well worthwhile, as is checking all the drain holes.
There's some good guides in the R170 pages, just use search.
A forum community dedicated to Mercedes SLK owners and enthusiasts. Come join the discussion about your R170/R171/R172 SLK, or AMG performance, modifications, troubleshooting, maintenance, and more!
