I have a 2002 slk 320 that I purchased used. The vehicle is missing the radio amp. I ordered a used amp and after recieving it i noticed that it is was removed from a 1999. The part number is the same, but the amp connection is different. Is this correct, or am I looking at the wrong connection for the amp? I opened the left side compartment in the trunk to expose the wire harness.
Please update your location/vehicle (model and yr) in your profile as it helps the members answer any questions you might have based on locale and model.
and i would post this in the slk r170 section as that is what u have
And finally, if you find something useful on your visit here today, please consider donating to offset development and operating costs. Even $5 is welcome! Thanks!
Thread Hijacker
Just moved this to the r170 forum, so it will hopefully get a better viewing...
Good luck with the problem.
dj
The amp should be on a metal panel in the passenger footwell ,if you pull back the carpet & remove the piece of polystyrene you'll be able to find its mounting location
Bose amp
Hello I have this amp in my SLK. It's a Bose amp.
Does someone know the Bose amp specificacions? Power? Speakers ohns? Numbers of ways?...
Tks!
