Boot / trunk won't open on slk 1998 convertible
5881 Views 17 Replies 10 Participants Last post by  allmac
How do I open boot / trunk on a 98 slk when the pull across to open roof Cnt b accessed ?
1 - 18 of 18 Posts
Moved your thread out of general discussion to here, the r170 general discussion section
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
See less See more
you're saying you cannot use a key or open the trunk?
No neither key will open boot
might need to be drilled. check these threads and please take 30 seconds to update your profile and post an intro thread
https://www.google.com/webhp?source...-8#q=site:slkworld.com r170 cannot open trunk
open boot/trunk
hi,
update your details, car, model, location, etc.
if you are in uk i can talk you through it on the phone.
it involves no drilling, cutting or damage of any sort.
have done it for my 2 cars and a couple of other peoples.
:smile:
Reactions: 3
hi,
:smile:
Agreed! No drilling!
Stating the obvious, but you do realise there is a handle recessed next to the key barrel?
Only mention it because the windscreen fitter didn't and tried a few too many 'tricks' for my liking, before he asked me.
Pre and Post facelift are different.
Reactions: 1
Yeah definitely don't drill without trying all available possibilities first. Sometimes you can get quite a lot of gunk inside the barrel, might be worth cleaning out. I'm thinking some sort of lubricant such as WD40 and compressed air. I'm sure there are better ways out there though.
No more news...???
I guess Peewac finally got the boot open, then locked himself inside....:wink::wink:
Would be an interesting discussion between him and any passers by though!
Reactions: 1
No peewee sold car to me,and I can't get into trunk key won't enter the barrel I think he mangled it,plus roof won't open,you get pump noise when push to close,but nothing when pull to open,Can the roof be open manually
allmac
See less See more
the roof can be opened manually, but you need to open the trunk to do it.
I believe the way that markja and ichris are referring to "tricks" the car into thinking that the trunk cover is in place, so the roof will operate. I don't believe that the key itself operates the lock, it signals the PSE to activate the system. If the line to the trunk isn't working, it cannot be unlocked. The "trick" is to jump the roof system with a wire under the hood. Mark and Chris may know the specifics. Once the trunk is tipped back, it can be manually unlocked. If the pump isn't operational, it may be a 2 person operation, one to operate the switch and the other to pull back on the trunk if the hydraulic system isn't working. Good luck.
Tim
El Torro is correct. There is one wire under the bonnet that is earthed to fool the system into thinking the cover is in place. MAKE SURE you do the correct wire. Wrong one can cause big damage to electrical systems!
I use a pin to spear the wire core inside the plastic casing so no damage to the wiring loom. (Except a very small pin hole)
Thanks Tim,
I have tried the grey and purple wire to earth but no luck,It looks like I may have to drill,like I have read in a couple of old threads,
but don,t know where to cut hole and what to do when cut.
thanks Mal
1 - 18 of 18 Posts
