1 - 20 of 34 Posts
· *Premium Member
2007 SLK280
After 17 years with my 280, I refreshed my crusade for Bluetooth access for the phone; I purchased a puck and cradle from the proper era. The '07 has the pre-install connectors to the COMAND and I can open the connector access below the top console lid where the cradle should fit. Problem is that the connectors are in a small storage space beneath the upper lid where the cradle access fits. I don't want to horse the access panel if there's a "right way" to remove it. Similarly, I'll need to find a path from the cradle wires to the pre-installed plugs below. If someone can help me understand the process, I'd appreciate it. Adding pics to both the access panel and the plugs, if that will help. Also adding a pic of the puck and cradle purchased. Anyone who might have captured pics of the process, please point me.Thanks.
· *Premium Member
2007 SLK280
Discussion Starter · #5 ·
I think I'll give up for the moment. It IS bothersome. I've removed most of the front console in the past but I may just try to push my way through this one. Gotta be easier than this. Thanks for the pointers, though. Will try to report back when I have it mastered.
· *Premium Member
2007 SLK280
Discussion Starter · #9 ·
Update: It amazes me that this hasn't been an information- and photo-rich topic for this long but with luck, I can address it at least better. Not trying to solve the head unit issue, though. Just trying to make mine work the way it was intended 17 years ago.
I received the ancient puck and cradle in today's mail. Using a box cutter, I opened the nesting spot for the cradle in the side-opening armrest lid. But a path for the cradle wires was blocked. Second pic is the bottom of the upper lid with the OEM pre-install wires in a flip-down panel. At this stage, I'm almost certain the four tiny screws in the large panel above are tiny torx that should open a path of wires from the cradle to the pre-install connection. My problem today is that the smallest torx bit I have is a T10 which is too big. I ordered a set online that starts at the T4 level and it's my hope that's the answer. Maybe no more than one additional step. Looks like I may never have the missing bottom panel of the puck but inconsequential if it works.
Yes, I could plug it in now and test but what's the fun of that? Don't close the thread yet. I'll want it again if and when I have to take all back out and have forgotten all this.
· *Administrator (Premium Member)
Fingers crossed that you are creating a reference thread for others.
The reason it may be an uncommon retro fit will likely be an after market head unit chosen.
That gives better sat nav, wider music choice and all the modern features that these cars should have had as standard.
· *Premium Member
2007 SLK280
Discussion Starter · #11 ·
I agree it will probably seldom, if ever, helpful to others who want to invest in a better head unit with BT already built in. But I'm still pretty satisfied with the Original HK system, it's 11 speakers, Sirius and amp. Living these days without Bluetooth, though, ain't an option if I can make it work even with old stuff. The other car, a 2019 luxo SUV, has all the bells and a Bose sound system so I know what the SLK ought to be. If I judge by the number of these pucks on eBay, I'd say there's still a thriving market for them. The cradle is far more rare. So I'll try to complete the set and hope it helps someone, someday.
· *Premium Member
2008 SLK350
That is exactly what was needed. Tells the whole story...more than I needed but thank you, @Sneaky Pete. Confirmed where I was going so now it just looks like I need to wait for the T8 torx. Very much appreciated. I tried reaching to Bill's Den but had no luck. thank you.
You're welcome. I knew I had seen this document but was not sure if I had downloaded it. Did a search on my computer and it popped up in some obscure folder where I obviously had saved it several years ago. 😁
· *Premium Member
2007 SLK280
Discussion Starter · #16 ·
Many thanks for the effort and the pack rat foundation you've obviously nurtured. I've tried to save things I thought I might once use but my intuition back then wasn't nearly as good as necessary. Apparently. But if you need the manual to a dot matrix printer, I might be able to help. Thanks again.
· *Premium Member
2007 SLK280
Discussion Starter · #17 ·
Update: Torx T8 worked on the false floor but the floor refused to separate. Cradle fit the cutout but would not snap in; remains loose. Despite the recalcitrant false floor, I threaded both cradle plugs to the pre-install connectors but when connected, the puck refused to light when activated. Fuse chart points me to three in the trunk, one in the cockpit and one in the engine bay, all associated with "Telephone Systems." PDF from @Sneaky Pete indicates only one fuse specific to the phone component activation. I'll start there. Will disregard two (41, 64) linked also to clearly working components and check 3, 8 and 13. Then, if nothing, probably enter the "stew and brew" phase to create a lovely note to my eBay "buddy." Any pointers to the correct fuse would help. Thanks.
· *Premium Member
2007 SLK280
Discussion Starter · #18 ·
Sidebar to this thread that may save me some time. Has anyone with the387 Mobile Pre-Install option ever been called on to replace or add fuses when they installed cradle and puck? I don't relish pulling the center trunk panel just to look for the presence of one fuse. In that same line, how would I test for power in the cradle's power supply connector? Ultimately, I guess I'm more suspicious of the eBay supplier than the folks who built the car as "almost ready."
· *Premium Member
2008 SLK350
I am not sure what option 387 exactly entails. Is it just the hardware with the exception of what you now just installed? Or do you also have to configure the car as described in step K of the installation document? When you cycle to the menus in the mfd is there a telephone menu? If not,the problem might be that you need first to perform the coding as described in step K.
· *Premium Member
2007 SLK280
Discussion Starter · #20 ·
I suspect someone deep in the files could tell us what MB said was needed to fully-activate the 387 option but I've never seen a thread mentioning anything more than addition of the cradle and puck. The seller of the puck said it tested good when it was removed from a 2008 R350 but...he's the guy who sold it so who do we trust? My screen simply says phone not installed. I'd expect that if the cradle wasn't registering. Is there an easy way to test power to the pre-install supply plug (ten-pin)? One online video suggests with time and use, a wire may have separated there near the hinge. But if it needs re-coding, I'm hosed.
1 - 20 of 34 Posts
