Registered 2001 SLK 230
ok here is my unique problem. my dash trim under the steering wheel is pretty bad and barely hanging on. if i hit it with my knee as i get in the warning light for a light out comes on. all lights work BUT the blinkers wont work. the emergency flashers will work but not if i use the blinker lever. i can sometimes tap the trim and it will go off.any help with this? i just got a new trim piece so im looking to fix the whatever is loose under there. thank you in advance for your help in locating what i need to fix.
Hi Hawk
It sounds similar to a problem I had with indicators (& reverse light)
