1 - 2 of 2 Posts
Registered 2011 SLK250
Blinker "touch" functionality: increase blink counts
Are you using the blinker's touch functionality, where you do not fully engage the switch, just touch it up or downwards?
Have you ever had the feeling that 3 ticks is not enough, and that by the time you are actually turning, the blinker no longer blinks?
Then this guide is for you!
I have found, in the SAM-F descriptor, the ability to increase (or decrease) the blinker counter, when you use the touch functionality, of the switch, to up to 5 times.
As always, keep in mind you have to run the Write to EEPROM and the Hard Reset functions, after making changes in the Front SAM, otherwise, your settings will reset, when you restart the vehicle!
Enjoy!
Registered 2018 MB Vito (W447)
thx .. however , my one come with CBC instead of SAM F only come with door lock blinker . no luck.
1 - 2 of 2 Posts
