I'm going to start a thread soon regarding the conversion of my "Depo" headlights (which were for LHD) to Bi LED projectors (which ARE for RHD). I have just completed the work.. However, before I do that, I've hit a problem .... The Depo's have bulbs with two filaments, one for low and one for high beam. The stalk to the side of the column is used to select high or low beam. Simple! The Bi-LED projectors, however, use one beam and the high setting is achieved by a solenoid being activated to deflect the path of the beam. The way things are with my conversion is that I do get the dipped beam but when I go to high beam there's nothing. Yes, the solenoid has received power and has operated but there's now no power to the LED projector. I need to find a way to not only have the solenoid operate for high beam but also still have power to the LED projector beam. I hope that I've explained this in a way that's understandable. I'd appreciate your help in solving this problem.
David
David
