This morning check engine light came on.. check code P0410
- Faulty Vacuum hoses damaged
- Faulty Air Pump inoperative
- Air bypass solenoid harness is open or shorted
- Air bypass solenoid circuit poor electrical connection
- Air bypass solenoid leaking/blocked or stuck open/closed
- Air diverter valve leaking/blocked or stuck open/closed
What does this mean? What does this mean?
When is the code detected?
The secondary air injection system does not detect the presence of air in the exhaust when introduced by the secondary air injection system.
Question will it be high dollar to have fixed and until I can get into the shot and get it fix is it safe to drive?
jnc1948
Registered 2000 SLK320
Hi have had a similar code on my 320, did quite a bit of research and found that it could have been a faulty brake switch ( had problems with auto box gear selection previous week ) renewed it and have had no fault codes since.
Regards Stuart.
Ps did not have the cel so could be secondary air.
