I had my gearbox serviced last week, due to some leakage that had been occurring in that area. Replaced filter and gasket, and refilled with oil, and new gearbox screws. As an education piece, what is the benefit of doing a gearbox service especially after a long time (regardless of leak).
5 Benefits of Changing your Transmission Fluid
Posted on March 29,17 by cccadmin
One of the most commonly overlooked aspects of a vehicle is the transmission. Many people tend to either ignore their transmission altogether, or simply do not understand how it works. And that is fine and dandy until the day comes that things start to get ugly with it. A busted transmission is another way of saying a car that isn’t going to be running anytime soon without some serious work. The transmission is the power source, and it provides proper application of the power of your vehicle. So if you want to ensure your vehicle’s transmission lasts just as long as possible (and most will last the entire vehicle’s life time if maintained properly), then you will want to get on top of changing your automatic transmission fluid.
Benefit #1 Preventing Lock Up
Lock up happens when your vehicle’s transmission gets so hot that your vehicle simply shuts down. It no longer runs. Changing your automatic transmission fluid when it turns black can prevent this happening to your car.
Benefit #2 : Saving Money
Who doesn’t like saving money? Changing your automatic transmission fluid when it turns black can help prevent most transmission problems from occurring, meaning you save the woes of a blown transmission.
Benefit #3 : Run Cleaner
Changing your automatic transmission fluid, and using the right fluid, can make your engine run cleaner and more efficiently than it has since it was brand new. This means better fuel economy (which we’ll get to next) and better oil usage. However, using the wrong fluid, any fluid not recommended by the manufacturer for your specific make and model, can damage your transmission greatly, so be sure to check.
Benefit # 4: Better Fuel Economy
Less work means less wear. Less wear means your transmission, and your engine, last longer. Changing your automatic transmission fluid when it turns black can help you to keep your transmission running strong for a very long time, making your vehicle more fuel-efficient.
Benefit #5 : Cost Effective
What do you think costs less: a new transmission, or automatic transmission fluid? Hopefully, you went with the latter choice. A new transmission is expensive, while automatic transmission fluid is relatively cheap in comparison. Taking care of your transmission means a better running car.
Excellent - thanks.
