Registered 2014 SLK250 cdi
Hi.
I have a SLK 250 cdi R172 which I am now going to lay up for the remainder of the winter as the roads are now becoming covered in salt, I have a Ctek charger which I am going to use, my question to all fellow readers, is :- If I connect to the "Post and Bolt" this method should keep the main start battery charged, but will it also charge the " Eco start/stop " battery at the same time, or does the "eco" battery have to be charged separately.
Mike
your profile says 2005 slk 200??????
Profile now updated as the 2005 slk 200 was my last car which I have replaced with a 250cdi
Premium Member 2018 SLC43
My 2018 SLC doesn't have the back-up battery behind the passenger seat, that early R172's had (y)
But yes, flip open 180' the Black/Red cover for the (+) jump start point under the bonnet & Your be able to close the bonnet while the CTEK leads are connected:
571935
This is a long thread about the CTEK Comfort lead that I fitted on mine:
Install Details: R172 CTEK Comfort Lead - RHD Install..
