Good Day....My head scratcher is a 1997 SLK230 RH drive....I have searched and searched and have found quite a few suggestion on this issue, however I have also found on the threads that a lot of people have got no real solution to the problem. So I have a few questions now and any help would be great and hopefully start me down the right road. First off I am showing no CEL but the light does come on when I start the car so I'm pretty sure it's not the bulb. I have not got the 38 pin cable adapter for my OBDII reader yet so I cannot check if any codes are showing up. I will be doing a complete service this weekend because I just bought the car and it's just a habit of mine to do this with every car I buy right off the get go just to make sure. So it's getting new air, oil, fuel, cabin filters as well as new oil...Q1. Any recommendation for best oil for these engines?? But the problem is...If I put the throttle right to the floor I get a big lag like it going to stall then a slow climb for about 1000 RPM then it just starts to drop off the RPMs and will start to sputter. If I just ease on the throttle it will climb all the way up. If I go to manual shifting and keep the RPMs around 2500 - 3000 it will respond fairly fast and usually not sputter. I disconnected the MAF and it had no change but this time it almost stalled at idle after a full throttle application. In addition to that it doesn't feel like it down shift when you give it a full throttle application while driving to say pass another car. Acceleration is about 0 - 60 in about 11 sec a far cry from the 7 sec it is suppose to be able to do it in, It seems like the tranny is stuck in winter mode. Has anyone heard of this being an issue before? I am going to do all the checks during the service just to be sure MAF, K40, Vacuum lines. Any help would be great, otherwise I will let you know how all this goes....Cheers
