Hello dear Forum,
I am glad that i am member now. :rb
I own a Mercedes Slk R170 200 my2002.
It has 120k km.Recently i got the infamous p0410 cel.
The car is running great but the cel has made me nervous.
I have read everything about the pump,the valves,the relay and i think i know what to check.But my problem is i cannot find the pump.
Could you help me and point me where this damn air pump is?
Also i took out the K40 and although everything is fine i found this odd connection pointed with the circle.Should this be there? It doesn't look right.
Thank you in advance. :Beer:
‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’. Profile is NOT updated in your ‘garage’.
We’d like you to post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. http://www.slkworld.com/new-members-introduce-yourself-here/
Hello dear Forum,
Did you pull the error code with a generic code reader or did you use one designed for Mercedes? The reason I ask is that I used a generic code reader - in fact I had the guy at my local auto parts store pull the code for me - and I got P0410. I did the same thing you are doing, and almost tore my motor apart. Then I decided to just take it in for a service yesterday and it turned out to be something completely unrelated to the emissions. It was a faulty relay switch in the brake pedal.
Make sure you use the right device or you could be barking up the wrong tree.
You may be right... The man that checked the car should have used a generic reader. But the authorized service asks about 35$ to just read the code.
Anyway do you know where the air pump is?
I would like to be sure that it is working before i look for other things or visit mercedes service...
No I don't, which is why I took my car in and paid someone to figure out what was really going on. But maybe this will help:
http://www.benzworld.org/forums/r170-slk-class/1278788-slk-230-code-p0410-air-injection.html
BTW, no one will pull that error code for free unless they are using a cheap generic code reader. I would spend the $35.00 and find out what the real problem is before you waste any more time.
