Hi All,
I have a 1999 SLK230 which has developed a really annoying vibrating/rattling noise which seems to be coming from around the gear box. It kicks in around 2000rpm but anything below that it disappears, sounds like some loose change has slipped down somewhere. I have had the the transmission fluid and filter changed and have also had the centre consul out but can't see anything that might be causing it. Can anyone please help with this?
Thanks in advance
Founding Member 2006
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
Have you had the motor mounts and transmounts changed yet?
Hi All,
Thanks in advance
Check the cross braces (struts). One of mine had rusted through and was vibrating against the underside.
