1 - 14 of 14 Posts
Had my rotors done today (original rotors, 102000) and pads
Taylor from c2design doing his 'most excellent' work again! Thanks Taylor
Akebono cross drilled front rotors, OEM rear ones, Akebono Euro pads….
Dropping off but I stayed to watch and take pics :D
Taylor needed a nap :D
Old rotor
Discussion Starter #2
more..........
Old
old rears
new rears - protective coating comes off
rear
Next upgrade will be rear 4 pot calipers + drilled rear ventilated disks and front 6 pot calipers + floating disks?
No. Next is the LSD :D within 2 weeks or so
Registered sold both-> SLK350, SLK '55
congratulations on a job well done.
Usually when I watch, my mechanic he charges me more.
Hope this has not happened =?
I removed my chrome lug covers so got a BIG discount and the paint job on rear calipers was free :D
On the subject of FRONT Akebono pads, I found this...
Brand: Akebono
Part Number: EUR847
Item Condition: New
Item Description: Disc Brake Pad Set
Manufacturer Brand Description: Euro Ultra Premium Ceramic Pads
Quantity Needed: 1;
Position: Front
Item Specifics:
UPC: 821726103734
Application Summary - 2000: Mercedes-Benz C32 AMG 04-02, C55 AMG 06-05, C230 04-03, C350 07-06, CL55 AMG 02-01, CL500 06-00, CL600 06-01, CLK55 AMG 04-03, CLK500 06-03, CLK550 09-07, CLS500 06, CLS550 11-07, E350 09-06, E500 06-03, E550 09-07, ML55 AMG 03-00, ML430 01-00, ML500 05-02, S55 AMG 02-01, S350 06, S430 06-00, S500 06-00, S600 06-01, SL65 AMG 07, SL500 06-99, SL550 09-07, SL550 12-11, SL600 02-00, SLK55 AMG 10-05, SLK350 06-05
Product Description - Extended 240: EURO Ultra-Premium Disc Brake Pads, designed & formulated to address the needs of European car owners: optimal performance, cleanliness & rotor compatibility. They are environmentally friendly & satisfy 2021 low copper content regulations.
Long Time Member 2005 SLK350
I think my 350 has same brake set up as some of the 55,s
I have just changed mine to the following
Fronts genuine merc discs with ebc red stuff pads ( changed from brembo due to fade at high temp and lots of dust )
On the rear I have gone for Brembo extra discs and brembo pads over the standard merc rears.
Done
Brand: Akebono
Part Number: EUR847
Item Condition: New
Quantity Needed: 1;
Position: Front
Item Specifics:
UPC: 821726103734
Note to others, these do NOT fit the early 6 piston calipers. They are about half the size. Akebono's own website says these are the ones, but they are not even close. I am glad my stock ones are fine, they will stay in. Now the search restarts to find a low dust pad!
Registered 2009 SLK350
GLAD you have shared this as i had found the Akebono web site and was not sure if they are the right ones or not .. the rears cross reference correctly but the front there is no cross reference to the 6 pot front discs OEM numbers
1 - 14 of 14 Posts
