2010 SLK55 AMG
Hi, I'm in the process of having the air con compressor replaced due to a leak. Will this mean that the system will need resetting with star? or could I just check for error codes and clear them with an obdII scanner. Thank you all. Geoff
2005 SLK350
Most likely your OBDII scanner will not reset the A/C controller so a hook up to Star will be necessary. Does the shop that is doing the compressor replacement have the Star system?
2010 SLK55 AMG
Discussion Starter · #5 ·
All done. It did need recoding on star and it works great now. See my post in the uk section for recommendations for local aircon and star in Coventry UK.
