So have any of you fine folks tried an AirBox upgrade for more flow & Zip that looked like this?
If the whole purpose is more air ???
Also do those little "fans" you place inside the air tubes I've seen online help?
Hmmmm ....
Steve
Premium Member 2002 SLK230K
Don't waste your money on those little turbo fans its a gimmick. You can go with an aftermarket high flow filter or an open cone type filter for more airflow.
any power gains from just changing or altering airflow to to your slk will be at best negligible (unless of course your currently running a completely filthy blocked airfilter)
Premium Member 2006 SLK55 AMG
I have a similar Air box as you have pictured, I think it's quite nice and doesn't get as much heat soak.
