1 - 14 of 14 Posts
When I was ordering my head unit I searched the forum for a long time trying to find if someone had used the factory microphone with an aftermarket unit and I did not find anyone who had.
The first thing you want to do is remove the A-Pillar on the left side. http://www.slkworld.com/171272-post2.html
Under there you will find two bundles of wire. One bundle looks like nylon rope and within that bundle you will find a black wire that is thicker than the others. Inside that black wire is a white wire and a wire shield. These will connect to the white wire and shielding wire of your microphone wire from your radio.
Does that make sense? I can try to get photos if you are interested.
Discussion Starter #2
Here are some pictures.
The grouping the microphone wire is in
The microphone wire. The shielding and white wire come out of the thicker black wire.
Soldered and shrink wrapped.
Are those wires going all the way to the original wiring harness of the NTG2.5? It looks like there are two wires going to two microphones according to the pinout. The original pins are
1 Microphone 1 IN+
2 Microphone 2 IN+
3 Microphone shield
4 ~ 6
7 Antenna Power (+12V Output)
8
9 Microphone ground
10 ~ 12
Could I just rewire those with the aftermarket harness instead?
1 Microphone 1 IN+
2 Microphone 2 IN+
3 Microphone shield
4 ~ 6
8
9 Microphone ground
10 ~ 12
First please update your location and vehicle (Put Looking!)(year?: 1996-2018, model?: 32, 43, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
On a smartphone: http://www.slkworld.com/new-members-introduce-yourself-here/330737-how-update-your-profile-post-intro-smartphone.html
Just curious, how did you figure this out? I tried to do a similar mod yesterday, tapping directly to the two wires from the mic, but people couldn't hear me in my test phone calls. Is this essentially the same thing? Maybe my connections or microphone are bad.
From what I've read elsewhere, the impedence of the factory mic is different than most after market mics.
who are you asking your question of?
please use the 'quote' button at the bottom of any post you wish to reply to or reference or ask a question of
fyi, op ichris has not been back on since
Last Activity: 04-24-2017
Ah, I was asking ichris, but really anyone who can answer the question. How is this different than connecting to the two wires from the OEM mic directly?
Has anyone else done this mod? Happy with the call quality vs an aftermarket mic?
You might, just might, want to start a new thread with your issue with any additional info
this thread was started in 2015
some members have their view set up with oldest last so as to not venture into old threads
Some experts might venture in :D
Premium Member 2001 SLK320
There are several sorts of mics, dynamic and condensor, either can be with or without a preamplifier in the mic.
Get this bit wrong and there will not be a happy result. Getting the wiring wrong can damage mic or more than that.
They have different characteristics, Dynamic mics can be preferred in light aircraft where the mic is close to the person as it is very good at removing background noise. A mic for a convertible might be quite different to that in a sedan due to wind buffet issues.
Older radios will be designed for a particular type of mic. Some modern ones are electronically switchable in aircraft but probably not in car systems.
First job is to figure out what the original mic was, then what you have.
I don’t know much about mics, but I know it’s best to find someone who really knows about mics.
Don’t assume you’ll find that person in a music store. An aircraft radio repair workshop maybe a place to start.
3 wires? Signal, positive, and ground? Mic wires can be really really tiny and hard to solder or join in a robust way.
If you have a new head unit, why not just use the mic that goes with it, but mount it into the place in the int.lamp assembly where the old one goes? Running the lead is easy. Then it’s plug-n-play.
What did you ever figure out, was your mic bad? I have been looking to do the same thing and was glad to see this thread. I was going to run the new mic wire up to the stock mic, but if it does not work I will not go thru the trouble.
tip 4 u!
Use the 'quote' button so we know who you are asking or replying to or referencing.
Thanks, did the stock mic work with your head unit. I have read conflicting information about the compatibility of newer units with the old stock microphones
1 - 14 of 14 Posts
