1 - 9 of 9 Posts
Hi, My fenders are rusted out. All the aftermarket ones I've found have holes in them for a turn signal. At least in the pictures. Oddly same thing with the M/B parts catalog.My version does not have a fender mount turn signal. Does anybody know where I can find left and right front fenders without a turn signal cut out 2002 SLK 230
Mercedes Benz dealers do the facelift fenders for about £210.00 each, these have no hole for side marker light and usually are delivered to dealer two days after order in U.K.
Available in US??
I was debating about having my fender fixed or replaced. Is there anyplace in US to order the fender without the turn signal hole?
fyi, wolf! has not been back since Last Activity: 09-05-2017
Yup. I was just fishing to see if anyone else can answer.
I will probably have to buy the fenders with turn signal holes and have the body shop fill/cover them before painting.
I have spent the last 6 months restoring the interior a piece at a time. Now for the exterior.
Hi all,
I gave up and got the only ones I could find, with light holes. I put scoops over them. carefully chosen and applied I think they work. BTW I went aftermarket and the fit was off, and doesn't align 100%.
Happy and merry whatever,
Wolf.
Look who showed up! He knew we were talking about him :D
Hi all,
That's what I had to do some years ago, before the post-FL fenders/wings became available here in the UK
The pre-FL fenders/wings bolt straight on, just 'glass the holes from the inside and fill 'n smooth from the outside.
I really would try Mercedes over there first tho just to see if they can get you a pair at a reasonable price.
As Wolf! has pointed out, aftermarket items will require some "fettling" (understatement) and if there's not a huge price difference you'd be better off with genuine Merc parts in the long run.
£210 here works out @ $280ish over there? each
GL
1 - 9 of 9 Posts
