So.....bought a breakered OEM steering wheel for my model year with a view to getting it re-covered / customed. (Great Christmas present!) ?
Swapping out my original steering wheel for the covered one.
Question: will my ORIGINAL air bag module slot straight into the breakered / re-covered steering wheel with no issues or throwing codes?
I know the air bag modules are a separate piece. I bought the steering wheel without the centre air bag module because I want to use my original one.
See what I'm trying to achieve? Should work in theory, right?
Any one done it? Thoughts? Theories?
Ta muchly,
Jo ?
*DAS/STAR Premium Member
2005 SLK55 AMG
If the old and new wheel are ethe same design, then yes, the airbag can be swapped over ..
Reactions: clown
2005 SLK55 AMG
.. and remember to disconnect the battery before working on the airbags!!
Reactions: clown
Discussion Starter · #6 ·
Thanks all. Feel better now I have your reassurances. ?
BTW.... @Seanhump....I'm from Notts.
Planning on driving the girl over there from Germany at Christmas.
Stopping at friends' in London then up to parents' in Worksop. We'll wave on the way by ?
You're all clever devils. Thanks,
Jo
2004 SLK200K
As Sean said, no problem so long as the battery's off whilst you do the swap, btw you'll need a good quality 10mm allen bit and socket wrench to get the holding screw/bolt loose, they can be pretty tight !
