I have a 1999 SLK230 that I have replaced the pressure pump and all worked great for the last 6 months. Now when opening the top, the top gets stuck on the rear cover. It seems the rear cover no longer flips up past the 90 degrees. I can manually move the cover and the top misses it and opens all the way. Closing the top the front edge hits the rear cover and snags.
Fluid level in pump is good.
I added a washer under the top screw holding the rear cover on to give it more angle. It worked for a couple weeks but is now snagging again.
Is there an adjustment to get the rear cover to go up to or past the 90 degree point?
I have looked in all the manuals I can find, but none mention the mechanical movement.
Can someone direct me the the right place to see it there is an adjustment that is not right or tell me what needs to be adjusted.
thanks,
Skindiver
thanks,
Skindiver
