1 - 14 of 14 Posts
I`m still in a dilemma about my suspension and think it would be best if I could get hold of some adjustable units.
Can anyone suggest where I may get some?
There are plenty on ebay but nothing specific.
I really hope you can help.
Kindest regards,
Martyn
Sadly Woolly has passed away
Hi Martyn,
Why not contact Bilstein directly, explain what you require, and they should be able to suggest suitable part nos.
Thank you for your imput.
I looked at your link but the email link didn`t work so I will ring them on Monday.
Thanks again,
Martyn
Have found a path to there contact page and asked the question.
I will get back to inform members of the result.
Have a good weekend.
Premium Member 2002 SLK230K
There are adjustable rear camber arms you can get for the R170, i think they are around $350. As far as i know there is nothing offered for the front other than the concentric bolts which will give you very little adjustment.
livefreeordie...............Thanks for your imput. As I`m in the UK please could you supply the website for the suspension units you mentioned.
Thanks again and kind regards,
Martyn
I`m still in a dilema about my suspension. I fear I may have to sell my car unless I can do something.
I`ve added a profile for members to view and cast their opinions.
Hope you can help.
Regards,
Martyn
It`s been confirmed by a mechanic that the suspension has been lowered with yellow springs.
I now need some standard size springs.
Anyone in UK know where I can purchase same?....or Swop!!!!!!
Regards to all.
Martyyn
Euro car parts list them from £38 - £58 depending on make. I've heard dealer prices ar not to dear for suspension parts. If using ECP put in the code 'MBCLUB25' for a 25% discount.
HTH
Thank you Aycee. However I`ve sourced four over the past couple of days all I need to do now is find someone who is reasonably to fit them in Bristol.
Thanks for your help.
Regards,
Martyn
Discussion Starter #13
To Chris R
This issue is about my back.
In this area there are a host of speed bumps and unless I approach at around 3mph they cause quite a bad pain in my back.
I`m trying to improve the ride so I can continue using my SLK.
Hope this explains.
Regards to all.
Martyn
Makes sense to me - back pain is the worst and the SLK isn't really supple in the ride department.
Maybe something could be done with the seat? I believe it already has hydraulic height adjustment - perhaps a stronger hydraulic piston could be sourced?
Best of luck!
1 - 14 of 14 Posts
