1 - 17 of 17 Posts
Premium Member 2007 SLK55 AMG/2009 SLK55 AMG
We are now a two SLK 55 household. I picked up an '09 with 50K on the clock today. The 200 mile drive home was fantastic. I'm a proud papa of course. I will call this one Jolene. :) Overall in great condition, just a few things to fix:
1) The headlights have a little bit of cancer on them. I'm deciding whether or not to buff them out or put on a smoked cover over them
2) The middle part of the grill has a nasty gouge on the black plastic wrap. I'm not sure of the best way to fix it, replace the grill or wrap with something. Suggestions welcomed.
3) The driver seats needs a little work on the leather. I might just re-dye it. Once again, suggestions welcomed!
572007
572008
Area of the grill with the issue:
572009
Faded areas of the headlights:
572010
Congratulations!!!!!!!!!!!
get rid of egg yolk turn signal
get clear or smoked turn signals
see my albums for other stuff
I think I will certainly start with the LED license plate lights. As far as the clear side makers, easy to get and replace? eBay?
Jolene is beautiful!
Congratulations!
would you believe we have a thread on that? :D
but for amgs like ours 2009...a little bit of extra work
check the r171 diy section
NOTE: On some vehicles (V8SLK and jbanks experience), there may be a second screw located at the front end of the sidemarker. Hopefully this is rare as it will be a lot more difficult to try to remove that front screw. One can try to feel with fingertips to see if there's a front screw or not, or use a strong light source as it is partially hidden and blocked by a metal plate. See photo below:
check my albums and threads for other fun things to add
1 - 17 of 17 Posts
