Hi!
I am planning on flushing the brake fluid on my SLK280. One set of instructions stated, that you should remove the ABS fuse before vacuuming the fluid. I tried to search info in this forum about the fuses significance in this operation, but could not find any.
How do you see, is there a significance in removing the ABS fuse before flushing the brake fluid?
Thanks!
Thanks!
