Can I increase the diameter of the rear tires on my SLK55 about an inch without throwing off the ABS/traction control or anything else? I'm considering running 255/40/18 on the rear.
TIA,
Thomas
Thomas,
Thank you,
Founding Member/Sergeant-at-Arms/Moderator
Not recommended. Do a search on tire size calculator. A number of tire shops on-line also have the tire size calculator, e.g., tire rack.
So why aren't they recommended? Do taller rear tires (1" greater diameter so 1/2" taller) throw off the computer or is it a clearance issue? It's an esthetic thing, I just like the look of taller tires on the rear...
Registered 2010 SLK300
what is the original tire size?
aka John
18x35x245 on the '55. I'll have to look, I don't think there's an adaptation on the AMG for 40's on the rear. Not saying it's enough to throw an error, but MB does use rotational speed difference to manage ESP.
