And so much for a good start to 2013. 99 SLK 230 (105k) hinted a trouble by sporadic "no crank" situations. Following the postings of the forum have done the following:
Changed battery (old one had 2 dead cells);
Removed, inspected and re-soldered K40 relay;
Had the key/fob (transmitter) checked at MB dealer;
removed and tested the starter/solenoid....checked good.
Replaced K40 relay with brand new OEM from MB dealer ($149.00);
....and you guessed it.....still will not crank.
Called MB Roadside Assistance and towed (flat bed) vehicle to MB dealer in Dallas....on Friday.....still waiting to hear from them....while "patiently" gathering all the $$$$ for what should be a "nasty" bill. Did I miss anything here?
Sorry for your trouble
New members should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last. Remember to click 'mark forums read' under quick links when you leave.
Thank you,
Moderator/Founding Member
Premium Member 2002 SLK230K
Welcome from New Hampshire, does it crank with no start? Or just not cranking? If it's not starting it may be the cps. Are there any codes?
