1 - 20 of 23 Posts
Just bought a 98 slk230. Has some issues. 112,000 miles, roof pistons leak, some rust starting. door panel was unglued from heat, but removed it and used hot glue to reattach the plastic retainers and separation of panels. Good as new?. Fixed a vacuum hose, washed out the MAF sensor(was giving an engine light code).. Fog lights don't work. No manual with the car. What does the 2 fog light indicators mean, one green one orange on light switch. Where would the fuse be for the fog lights, didn't see it under the hood. Ordered the roof hydraulic fluid $9 and piston repair kit ebay$29. This car came with amg rims and emblems but not fancying the rims.
Welcome to the elite SLKWorld forum!
Just a few suggestions to make your time here a fun and informative experience...
The "Search" feature at the top right of the page is for searching the forum. Many questions have already been asked and answered by our knowledgeable members.
If you are having difficulty finding a solution, you can post your question in the appropriate discussion forum. By doing this, you should receive a quicker response, but please be patient as the forum is worldwide and members live in different time zones.
Private Message (pm) is a tool to communicate with other members privately for instructions or just chatting. In order to do this you must have at least 15 posts. It's easy to obtain the posts by clicking on the New Members Introduce Yourself Here section and just welcome the new members (like we welcomed you).
To post a picture, either start a new thread or reply to one, type what you want to say and click on the 'paper clip' just above, this will open a window to your left, click on 'browse', go to your pictures, and double click on the one you want to post, click on 'upload' and then 'submit' your post.
If you like a comment or want to thank another member for their post, there's a 'like' button to the right and just below is the 'thanks' button.
As a new member you can use the New Posts link at the top of the info bar. It's a great way to see all of the posts you have missed since you were on the forum last.
When you are ready to leave the forum just click on "Quick Links" and click 'mark forums read', this will clear your screen for when you log on again.
Post your vin in the Vehicle Data Card Request section to get a data card (options on your car) free.
As a member you have the privilege to vote and/or enter our Ride of the Month competition, we welcome new SLKs to compete and new members to vote.
If you have any questions/comments please let us know and we will be happy to help you.
Thanks for joining our SLK family!
Marykay
Florida Event Coordinator
Reactions: KillerB
Welcome from Sweden!
I hope you'll get her up and running in good order.
I haven't given the fog lights indicator much thought myself... I'll have a look in the manual and let you know what it says if you don't get an answer by anyone else soon
Premium Member 2005 SLK55 AMG
Hi and welcome from the UK Midlands! :)
I'd expect the 2 fog light indicators to be for the fog lights... one for front fogs and the other for the rear. I can't remember which way around they are, and I'm out of the country on vacation and away from my car right now, so can't check for you...
Reactions: KillerB
welcome to the site.. have you posted any pics.. is your car a good one? ive had a 98 for about 20 months and found it to be a really nice drive... hope yours is a nice car. kevin
Premium Member 2009 SLK55 AMG
Reactions: KillerB
Hi, welcome from Barrhead, Scotland. :smile:
Reactions: KillerB
The fog light indicators...
The manual says: When you have the lights on, pull the switch out one step and the front fog lights will turn on (green light). Pull it one step further and the rear fog lights will also be active (Yellow light).
Discussion Starter #17
Manley, the car seems to be a good one. i knew it had a few issues as the milage indicated it had been used by a doctor for most of its life, then traded in at auto dealer and then 2,000 miles over 4 years.
it gave a engine light after driving 200 miles, code was mass air flow sensor, which are know to get dirty/oiley. a can of cleaner and easy to clean. also noticed a loose plug on coolant temperature sensor at radiator. a bunch of lights were not working, blinkers on fenders, fog lights,(the wire to fog lights where it enters the foglight housing is a common spot where the wire breaks. i just bypass the connector on the housing and make a small slot next to the connector to run the wire into the housing, quick simple fix). rear fog light i have not yet located but believe it is a bright reverse light perhaps?
the roof pistons leak at the passengers side forward in the trunk. ordered the $30 repair kit with all 5 seals so ill do all 5 pistons.the hydraulic fluid from my local dealor(Smithtown New York) was $9.20, lists at $11.50 and the part # is 000-989-91-03-10
the passengers window needs adjusting as it goes up 5mm to much so the window will rest outside of the weatherstrip when door is closed with window up. another easy fix as the window stopper just needs adjusting down 5mm. good thing i have worked on cars for many years or this would be expensive repairs. anyone that needs help with how to remove panels correctly please feel free to ask ;) other than that i have to drive the car to reset the sensors so i can get it inspected.
the weekend is here! cant wait to drive!
Brett
1 - 20 of 23 Posts
