1 - 10 of 10 Posts
How do I remove the retaining fastener at the top of the hood strut? I have tried pushing, pulling, pliers, screw driver. Is there a trick to releasing it?
Thanks.
have you tried a search top right? a couple of threads show how. otherwise, wait for someone to jump in
You gently pry it off with a flathead screwdriver and push it back. The top retaining clip has a circle hole in the middle and squeezes at the end so when the hole fits the groove on the hood strut it won't slip. Or may be the 98 is different? which I don't think so.
replace hood strut
Thanks, I'll try it and let you know.
replace hood strut
Worked perfectly! Thank you, thank you!!
Glad I was of help ;-)
Jeff, I came up with the pdf DIY on how to replace the hood damper the other day but can't remember where... I have the PDF though. Do you think we can post it in our diy section?!
sure but it has to be attached to a post obviously, so make a title and thread and attach it there
the problem is I reached my 10 mb attachment limit :-( can I send it to you and you create a diy thread? :)
will pm you
1 - 10 of 10 Posts
