1 - 18 of 18 Posts
I was sold a PSE Model 1708000848 unit as a direct replacement for the original 1708000348 unit which was defective (wet). After installing the new unit, everything functions properly (door lock button & remote, trunk light, interior light, and rear defogger) with one exception.
When turning the ignition key on, there is a short blast from the alarm horn. (only issue)
I have tried unplugging the battery with no change. I also set off the alarm with no change. (I did note that the alarm is a solid stream of the alarm horn blowing continuously instead of a series of short blast that the previous unit provided.)
Can anyone please suggest how to stop the short blast when starting the vehicle?:confused:
Premium Member 2009 SLK 55 AMG
Premium Member 2005 SLK 55 AMG
Hi and welcome to SLKWorld.com from the UK Midlands - Thanks for joining us! :)
I can't answer your question about the short horn blast after changing your PSE, but let's hope someone will be along shortly to offer some advice...
Welcome from Wirral, England.
You say the old pse was wet, how wet?
Could water/moisture have got sucked into the system?
Might be worth taking the hoses off and giving them a hair dryer blow.
Cheap to do (free) and relatively simple IF the hoses will come off.
If necessary, replacement hose can be bought from aquatic centres for pretty much peanuts.
And thanks for updating vehicle/info data.
Makes future calls for help easier.
Thanks. The foam was dry with no indication of any previous moisture. The old unit had corrosion around the white connector with no current wetness on the outer surface. Upon opening the old unit, the PC board was damp with corrosion in the area of the white connector. I cleaned the connector and the PC board with alcohol and dried both with a hair dryer. Reconnected the old unit and it was still dead. Ordered a replacement.
Super Moderator
Hi and welcome from Lakeland, FL!
Living in Florida and joining the forum has special perks! We have a very active and fun Mercedes Benz SLK Forum - FLORIDA SLK and you’ll definitely want to join us.
Our last meet http://www.slkworld.com/u-s-florida/339161-florida-spring-meet-lakeridge-winery-picture-thread-april-9th.html
You can view all our meets at U.S. Florida - Mercedes Benz SLK Forum
We are planning the Fourth Annual Florida SLK Group October 29, 2016 in Lakeland, and we’d like you to join us!
http://www.slkworld.com/u-s-florida/362498-florida-oktoberfest-picnic-october-29-2016-a.html
Follow us on Facebook https://www.facebook.com/SlkWorld?re...homepage_panel
Thanks for joining the forum and we look forward to meeting you!
Marykay
Florida Event Coordinator
Ok, I doubt the water in the vac line theory then.
My sponge couldn't have got wetter if I dunked it in a bucket.
The pse poured water out when I removed it.
Much worse than yours but the lines were ok.
I presume from the above that you removed all the oxide from the connector?
Still worth checking the vac lines for kinks or splits. Either would reduce efficiency.
Also, check the battery age/condition.
Although I suspect it isn't the issue, the SLK needs a great battery
otherwise it has quirky electrical issues.
For age:
For explanation:
Discussion Starter #14
Itook my 98 SLK230 to my MB/BMW repair shop to have the PSE coded so that thealarm does not go off when the vehicle is started and the alarm to sound inshort blasts instead of one long blast. TheCAN (local area network for various modules to communicate) was unable to communicatewith the PSE, making it impossible to code. The problem with the CAN was determined to be the CCM module. After replacing the CCM module, the PSE wascoded and everything functions as normal. The problem isolation, PSE coding, and CCM replacement costapproximately $1700.00 US.
Are you sure the short beep is not the seatbelt warning beep? - whoops sorry, I missed that you had a solution, good to hear, sorry it cost so much.
Welcome from Australia
1 - 18 of 18 Posts
