1 - 14 of 14 Posts
Right turn signals not working front, rear and side. Left side works fine. Hazards work fine. Right side clicks twice as fast as when left side is turned on. Bulbs are not the issue. Relay is not the issue as both left and right uses the same relay. Is there a fuse for the right side turn signals and where is it located. Turn signal switch is not likely the issue as it sends the signal to the black box. Tried the hazards on-off trick but did not reset it. Help!
Thanks.
I Have the same problem. My left turn signal and emergency work fine, just my right turn is not working. I can hear the relay clicking but the light both inside and outside not blinking. The bulbs work fine as when i turn on my emergency, both sides blinked.
yachdude,
We’d like you to post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. http://www.slkworld.com/new-members-introduce-yourself-here/[/B][/COLOR]
no you didn't update your vehicle
now it is! you might have had it in your garage section and that section does NOT talk to the profile section.
I am having the same problem
Good day all.
I am having the same problem but am unable to find the solution on the link above.
I would appreciate the assistance.
Thanks for your time and consideration.
Same RIGHT turn signal only issue 1998 SLK230
Same issue as of the above other guys. Only my right turn signal side is not functioning. LEFT and HAZARD are fine. I see mention of a solution but I cannot find the link. Any help is appreciated. It sounds like this RIGHT turn signal issue is common.
FYI, this thread is 2 years old
always better to start a new thread for maximum exposure
1 - 14 of 14 Posts
