1 - 10 of 10 Posts
What is going on... I posted this in another tread but there wasn't any activity for a while.
Blown #8 fuse (antenna booster). Replaced it new fuse blew instantly... every time I put a new one in.
Please help!
Founding Member 2006
yes, always better to start a new thread than to have your question 'buried' at the bottom of an old thread.
Discussion Starter · #5 ·
Thank you Master Seargant.
Everything seems to point to a possible short but solutions to this have not really shown up on what I've read.
I'll continue to search and check back in on here.
2008 SLK350
Unfortunately there are no simple solutions. If the fuse still blows with the amp disconnected then probably you got a damaged live wire somewhere that has a short to ground. So that means a search, not here but in your car...>:D
2004 SLK200K
Yes, I tried to put in a new fuse both with the amp connected and disconnected. Same results OR it would blow after I locked then unlocked the doors with the fob.
Have you got an alarm system?
This is also protected by fuse number 8 and would be connected to the open/closing of the door locks!
Might be a good place to start looking.
1 - 10 of 10 Posts
