7G sport mode
2803 Views 22 Replies 11 Participants Last post by  hugy
In my 55 if I drive it in Sport mode the gearbox still changes up too soon as if in comfort.
Anyone else experience this.
(I normally drive in manual).
Are there any software updates for an '06 55?
1 - 20 of 23 Posts
I'm confused. The gears will still change from 1 to 7 in sport mode and comfort from 2 to 7
so it is normally in sport to get to top gear as soon as it can because you want 'speed', no?
Put your foot down to the Boards and it will not change until the Red Line>:D
Reactions: 4
But really, I think it will change up if you are driving casually, it does not know you want to keep in a lower gear unless you give it some and then it will keep itself in a lower for about 5 seconds or so after you have accelerated or driven briskly. I assume it is programmed to run the engine at a leisurely pace until required to go MAD>:D
Reactions: 2
Like I said I normally drive in M mode but sometimes in traffic I put it in S.
If driving slow in S mode does the transmission act like its in C mode?
On my 350 with 7G, 'S' is much like 'C', except it uses 1st gear and holds gears for a little longer on the way down. The changes can be a little more pronounced too. However, if I mash the throttle it red lines in every gear (well, I presume it red lines in 6th and 7th, I've never been that brave!).
Remember that it's a 'learning' gearbox, so your driving style will influence its characteristics.
Reactions: 2
Reactions: 2
Hi All
Im sure I heard that in Sport mode the gear will keep you in the that will give you the best power , So if you drive along leisurely it will go through the gears like being in C mode , But when you hit the carpet with the go button it will react very quickly & drop down not just one gear but more like three gears & hold that gear to the red line .
Cheers
Andy
Reactions: 2
As an aside, a lot of people don't realise that if you hold the 'down' paddle for a second it will automatically put the car in the optimal gear for accelerating, no matter what speed in 'C' or 'S'. I use this for when I'm waiting to make a cheeky overtake but I have to allow a car coming the other direction to go past first.
Reactions: 2
...and when you're done overtaking and just want to cruise in auto again, simply hold the 'up' paddle for a second or so and it'll return to auto mode (assuming you're still in 'C' or 'S'). :D
Reactions: 2
Great info guys,thanks.
Jeff I have done the reset a few times but I don't notice anything much.
You're doing it wrong then :D
deep breath. make sure car is not in garage or driveway but on level road. do it there
when done....floor it. oh and be in S mode.
S mode will behave like C mode if you drive casually.
The transmission will hold the gear and upshift later at a higher rpm (2500, 3000 and even 4000 or higher) dependent upon how fast and forceful one depresses the accelerator pedal.
This.
Unless you're really on the throttle, the difference between the "S" and "C" settings will seem fairly minimal. Find a road where you can really start to work the accelerator and you'll very quickly start to see the difference in the shift points and overall behavior.
By the way, etyu, that's a gorgeous color combination. Makes me want to find a good upholsterer in the area.
Cheers.
Reactions: 1
From my manual:
Select C for comfort driving:
 The vehicle starts out in second
gear (both forward and reverse) for
gentler starts. This does not apply if
full throttle is applied or gear
range 1 is selected.
 Traction and driving stability are
improved on icy roads.
 Upshifts occur earlier even when
you give more gas. The engine then
operates at lower rpms and the
wheels are less likely to spin.
Select S for standard driving:
 The vehicle starts out in first gear.
 Upshifts occur later.
See less See more
Why a level road Jeff?
Reactions: 1
In my logic, after resetting it, I don't want to drive slowly down my driveway and make a turn before I rip it otherwise, again in my brain, the reset will think I am a granny because I am driving slowly (to get to the bottom of the driveway) and resets itself to granny mode, instead of 'floor it' mode :D
Gotcha:smile:
I thought the whole adaptive reset was debunked by various bods at Mercedes?
And holding the "down" button doesn't select the best gear for overtaking AFAIK - it just allows you to set the highest gear you want the car to use so it doesn't change up; for example when you want to use engine braking downhill.
Also - I wish it DID have a 'hold gear' button - it's a 5.5 V8 with nearly 400lb-ft. I don't need to change down gears all the time when I want to accelerate a bit. I've seen how massively effective this thing is in all gears at overtaking when I'm in manual, but it'll do it perfectly well in 5th or 6th, I don't need it to slop down to 3rd to do it.
Yes, yes I know, "use manual" is the answer - but for 98% of situations C/S is perfectly fine, it'd just be nice to have.
Reactions: 3
1 - 20 of 23 Posts
