1 - 8 of 8 Posts
http://autos.yahoo.com/articles/autos_content_landing_pages/1013/6-Car-Repairs-You-Can-t-Afford-to-Skip
6 Car Repairs You Can't Afford to Skip
print send
Buzz Up! By Jamie Page Deaton
No matter what strange noise your car is making, it almost always turns into the ca-ching of your mechanic's cash register gobbling up your savings. Because car repairs are expensive, it's tempting to let them slide. But putting off or skipping certain repairs can be a costly and even dangerous game.
Here are six car repairs you might be tempted to skip to save a little cash. But we'll show you how making that call could cost you a lot more in the long run.
More from U.S. News & World Report
» Cash for Clunkers
» Best Car Deals for June
1. Brake Pads
It seems like common sense: Don't neglect your car's brakes. Still, when it's time to replace your car's brake pads, it's easy to look the other way. For one thing, brake pads tend to wear gradually, so you might not notice changes in your braking performance right away. Secondly, a car with worn brake pads will still stop -- just not as well. So what's the harm in saving some money and holding off?
It turns out the harm in not replacing your brake pads is about $400. When your brake pads are worn, they can cause damage to brake rotors. As the rotors rub against the worn pads, they become warped, which makes it tougher to stop the car (if you feel your car shudder as you brake, you probably have warped rotors). Fixing the rotors requires that they be turned or smoothed out -- something that requires a mechanic and can run over $100 per rotor. If the rotors need to be replaced, you'll end up spending four times what it would have cost to replace the brake pads.
2. Oil Change
An oil change should cost you around $40 at most quick oil change stations. And that same station will probably tell you to come back in three months or 3,000 miles. But do you have to? It depends. That old rule of thumb still applies to some cars, but others can go much longer between oil changes. To find out how long your car can go between changes, read your owner's manual.
After you've found out the oil change interval for your car, follow it. Oil is like your engine's blood. But unlike your blood, all sorts of impurities build up in unless your oil is changed regularly -- not to mention that all engines lose some oil. Too much buildup and not enough oil lead to your engine seizing up. Sure, you can save $40 by putting off an oil change, but you could end up spending $4,000 on a new engine.
3. Air Filter
Changing an air filter is cheap. It's even easy enough for most people to do themselves. Not changing your car's air filter, on the other hand, is expensive. According to the EPA, a dirty air filter can reduce fuel economy by up to 10 percent simply because your engine won't breathe as efficiently. By not changing a dirty air filter, you'll save about $15. But, if your car is supposed to get 25 miles per gallon, and gas is $2.50 a gallon, those savings have evaporated by the time you've driven about 150 miles.
Even worse, if the air filter isn't clean and that means enough air isn't getting to the engine, you could foul your spark plugs and might have to replace them. Depending on your engine, that can cost anywhere from $100 to $300. Now, spending $15 for a new air filter doesn't sound so bad, does it?
4. Transmission Fluid Leak
One of the most common problems associated with your transmission is a fluid leak. You'll likely first notice it when you see drops of red fluid on the pavement where you usually park your car. Ignore it for long enough, and you'll definitely notice it when the leak leads to your transmission shifting roughly, or the gears slipping.
Transmission fluid is what cools and lubricates your transmission. If it's leaking, you need to fix it, and fast. Resealing a transmission is a relatively easy job and should usually only cost a few hundred dollars. Ignoring the leak can lead to the transmission seizing up and a subsequent transmission replacement --which costs several thousand dollars.
5. Burned Out Lights
Here's one car repair on our list that is really easy to ignore. After all, a burned-out tail light won't eventually lead to engine failure or to your transmission falling out. While that's all true, you should still fork over your hard-earned $5 for new tail light bulb if yours is burned out.
Believe it or not, failure to keep your rear lights working can be an expensive proposition. First, if a police officer sees you with broken tail or brake lights, you're going to get a ticket. In some states, the fine for a broken tail light is $150, which makes paying for a new bulb seem like chump change. Second, broken lights increase your risk of being on the receiving end of a rear-end collision. And while the other driver's insurance should cover any damage (assuming they have insurance), you still have to deal with the headache of getting your car fixed.
6. Clogged Fuel Filter
An important part of maintaining your car is keeping impurities out of the engine. While the air filter does part of the job by keeping airborne impurities out, the fuel filter keeps impurities from the fuel out of the engine. Like the air filter, if it gets clogged and you don't fix it, you're looking at some major problems.
On older cars, a fuel filter is relatively easy to replace because it's easy for mechanics or car owners themselves to get to. On newer cars, it's a more complex job. More complexity means more money, which makes this repair tempting to skip -- despite the fact that it can lead to the car stalling or refusing to start altogether.
Don't skip it. At its most expensive, replacing a fuel filter will be a few hundred bucks. Let it go too long, and not only are you looking at dealing with a car that will barely run, you could also have dirt in your fuel injectors -- causing them to need replacing. Replacing just one fuel injector can cost over $500. But if they all need replacing, you're looking at least $1,000 in repair bills.
Discussion Starter #2
This got me thinking maybe I should change the oil. I was supposed to change it on february but after I got quoted $675 for service C i just resetted the computer. And greefilters, I should get some of those.
Founding Member #2
Engine oil and filter change I believe is basic to to the car motor's long term health.
D
Guest
Indeed it is mate.
Not a smart thing to do especailly if its your daily driver.
This reminds me, I have to clean my green filters. How often do you guys do this?
Also, how often do you all change your fuel filter in the SLK?
You should clean the Green Filters based on mileage and the area you are in. For example someone in Arizona may need to clean their's more often. When you clean them let them sit for a day before putting back in to let the oil get soaked into the fibers well.
My 2 cents.
Alright cool! Where is the writeup on how to clean them properly?
Founding Member #2
IIRC, the slkstore site has the instructions at the same area where you would order the green air filter cleaning kit. Also check the greenairfilter website. The filters are to be cleaned using the manufacturer's cleaning kit at roughly 40,000 miles, IIRC.
I do "dry" cleaning on mine every 4 months, i.e., remove the green air filter from the air filter box, tap them on clean cardboard (dirty side down) several times to remove particulate matter, use a pointed tweezer to remove weeds or small insects that may still be lodged, check air filter against a light source, replace green air filter.
1 - 8 of 8 Posts
