Hi Everyone,
I have a water pump, power steering belt tensioner that froze up and burned up the belt. I'm in the process of replacing it but I cannot figure out how to remove the tensioner assemble which looks like a requirement for its repair. Can anyone help with step by step instructions for this? Any help would be appreciated.
Thnaks
Dave f.
moving to the r170 general discussion section
The diy section is for already made diys
Someone will respond if they can assist and answer your questions
Hi Everyone,
Thnaks
Dave f.
Maybe this will shed some light?
Thanks JaysonM. This is exactly what I needed. I did not realize there is a nut under the shroud to take off the pulley. The bearing for the pulley is destroyed. I will find out today if the shaft is gone also. If it is I will need to replace the whole idler assembly.
Thanks again.
