1 - 8 of 8 Posts
Registered 2017 SLC300
getting the following engine code and description:
P0366 Camshaft Position Sensor "B" Circuit Range/Performance Bank 1
P04DB Crankcase Ventilation System Disconnected
Looking for solutions for these codes. Any guidance is appreciated.
Registered 2012 SLK350
As this is a 4 cyl is a bit more difficult to diagnose since you can't move parts around. I would start with changing the electromagnet.
As for the emissions you have a leak or something disconnected in that circuit.
what is the electromagnet?
más far as emissions, everything looks connected. I just need to check the seal or o ring and make sure it’s still intact.Would you happen to have the wiring diagram or the ohms/voltage for these connectors / sensors?
On the front of the engine in front of the camshafts, it's what varies the position of the oil flow control mechanism for the camshaft adjuster.
Yes, I see now. Do you know what the ohms or resistance should be? I also determined i would potentially need to replace it.
I'm not sure, you can compare it to the one on the other camshaft but since you are getting a performance error it won't tell you much.
I see, thanks. I’ll order the piece, which is about 40$, and replace it. I’ll provide an update after it’s done. Thanks
1 - 8 of 8 Posts
