Under warranty so you have taken it in right?
could be bad catalytic converter or exhaust brackets
It sounds like the exhaust manifold problem as noted in this thread: http://www.slkworld.com/slk-r172-general-discussion/59265-slk-350-exhaust-rattle-different-fix.htmlI have a vibration noise coming from the vicinity of the engine compartment. It occurs only when the engine is at operating temp, the outside temp is less than 60 F, and the engine RPMs are between about 2200 and 2800. Has anyone else experienced this?
Oops, my mistake.The exhaust manifold problem you mentioned is on the six cylinder engine. I have the four in my car.
thanks Wick63. I got my car back on Friday and the noise is still there. The paperwork from this latest check says 'Ounce, it sounds like you have the same problem I had. My car was repaired by my M-B dealer this week. They replaced both the intake and exhaust camshaft adjusters. Fortunately, my car was still under warranty and I didn't have to pay anything. The service rep told me the cost was about $3,300 for parts and labor. He also told me that the service technicians were able to reproduce the sound both when driving thFridaye car and when using some test equipment and that M-B authorized the warranty repair. After picking up the car I drove it for about 45 minutes and the sound was gone. Hopefully, it won't return.
Mine as well, but goes away after warmup. The ticking part sounds to me like hydraulic lifters that haven't primed with oil yet, and the rattling is definitely exhaust cats or something. After the car warms up it all goes away and I have no problems whatsoever, just the noise. I have learned to accept some noises coming from vehicles as it is a characteristic of the car. I don't fret the rattles or ticks too much as irritating as they can be sometimes (I'll fix these later maybe), but I do get concerned by more problem noises like knocking, tapping, roaring, or anything that seems excessive.I have a rattle at startup and tick over been in 3 time now been told this is normal, been given some bull no doubt
