Hey everyone,
I was about to fit this unit into my vehicle but in the end I ended up fitting a Comand unit, so now this is available!
Model MF2810, part number A 171 870 42 94 (single CD)
This is an European unit, but coded by John to work in a US vehicle. Supports Bluetooth, AUX-in, and media interface (if you have the cables/kits).
I'm also offering a leftover quadlock cable, can be purchased with the unit or by itself. It's the one from Frank, but I don't think it's needed for this install!
It's free if you want it.
This is a fairly easy retrofit if you have a pre-facelift SLK without Harman Kardon audio.
I haven't tested the unit myself, but John has. Everything seems to be working. :tu:
Letting the unit go for $275 + shipping. If you're in the LA area you can pick it up yourself if you want.
Any idea if this will fit into a 2006 slk? I bought a used one last week and it has one cd changer (no Bluetooth or aux port) so this will be great upgrade for me...
If your car doesn't have Harman Kardon speakers it'll be a relatively easy retrofit. You WILL lose the cd changer as the connectors changed. I'm assuming your car is US spec.
Note that in order for bluetooth and aux in to work you'll need to buy additional cables.
And you'll probably need to have the unit coded by a specialist.
