1 - 11 of 11 Posts
My transmission started doing this a couple of weeks ago. Here is what is does, while driving along it will start slipping and when I stop, put it in park, then back in drive, I only get first gear with no slipping....If I turn the car off, and restart it, everything is fine. I get no check engine or any kind of messages.
It did this twice a couple of weeks ago and again yesterday. The only thing in commom on these days was the outside temperature was considerably lower than the day before.
Anyone have these kind of issues? Thanks, cheers!
Have you had any trans service done? what is the mileage on the car?
Sadly Woolly has passed away
Hi Newman, welcome from NE England. How about filling in your details (via the User CP button) - it makes it a lot easier for people to answer your questions if they know what car (and country) you are talking about. JB will be along shortly to read the riot act to you!!
Newman, get the car to an MB dealer and have them run a diagnosis on the trans. My guess is there will be a fault code 2767, Faulty Speed Sensor. I hope you have, at least, some kind of a drive train warranty...and do as Woolly suggests; the more we know about your car & location, the better :tu:
Reactions: -1-
update your profile please:
Thank you,
Founding Member/Moderator
aka John
I'm with Galo here - find someone - either a dealer or an Indy - and have them hook it up to Star Diag and do a TCU diagnostic. Don't waste you time with anyone using some other tool, Star Diag is key...
Going with a diagnostic check sounds like the way to go:usa:
On an older vehicle i had the slipping was due to low trans fluid,good luck with this:tu:
Can anyone tell me how to check the trans fluid level? 2006 SKL280. Thanks!
1 - 11 of 11 Posts
