1 - 17 of 17 Posts
I have a small chunk missing out of my grille and think replacement is probably easier than repair. When looking to order a new part, I see two part #s keep cropping up: 1708800485 and 1708800685. There's a large price difference between the two but I'm not getting much joy from a couple of the parts people on what the difference actually is. Anyone order these and happen to know?
0485 is for a 200
0685 not found
again, post your vin
0485 is for a 200
0685 not found
Yes, you kindly provided me a data card for my VIN WDBKK66F54F303679 but I did not see mention of the grille.
However, from your links I found my way over to here and it looks like the code would be 1708800485
https://partsouq.com/en/catalog/genuine/parts?c=Mercedes-Benz&ssd=%24%2AKwEzBxYhZ0VUfF5hd29pE2t_X1hGNzg1NCYgL2lAfCR3Ij0nDxIISksxMEc1M0NrZnk3Nz4kLSJqZnpsaDA3NzI3NiUpeiUpIzolJC0iam56bGhHIiskYm4lP3pgclYiKyR3YyU_emdofAAAAAB6aIcI%24&vid=0&gid=10841&q=WDBKK66F54F303679
For examples of the price difference I was referring to, this is the 1708800685 ... $270
https://parts.mbfm.com/p/Mercedes-Benz_2004_/Grille-Upper--Lower/48195139/1708800685.html
and this the 1708800485 ... $157
https://parts.mbfm.com/p/Mercedes-Benz_2004_/Grille-Upper--Lower/48195139/1708800485.html
There is usage of terms w/sport and w/o sport, which may mean the with or without the star, but could not get confirmation, and the price difference is too large for that. Same price difference on other sites too.
0485
A170 880 04 85 is a charcoal grille.
A 170 880 06 85 PROTECTIVE GRILLE C170449 88 ATTACHMENT PARTS 135 RADIATOR GRILL
is for a c170 not your r170
Registered 2001 SLK320
I will no doubt get hammered if I am wrong but my belief is they are all the same for the R170. I haven't seen one that does not emulate the so called Cheese Grator style.
Be careful removing the Star out of the old one no matter which way you go.
I recently found a hole in mine which I suspect was a yahoo backing into it. It penetrated just below the hood lip driver side of the star. No sheet metal or paint damage but the grill came out in 6 major pieces and a hand full of bits from broken bracketss.
I decided to do something different and bought a more CLK style. I like it. It was $189 plus shipping.
Registered 2002 SLK320
Not for the purists but this little set up brings my "old skool" Roadster into the 21'st century IMHO :wink:
Although they are pretty good, I will be adding Xenons to those lamps at some point >:D
My picture did not apparently load but it is similar to what Dave has on his car.
This is the link. https://www.55tech.com/products/mercedes-benz-r170-slk-1997-2004-sports-grille?_pos=1&_sid=c9afa8d1a&_ss=r
The quality is excellent, fitment excellent as well and it is a 10 minute fiddle to change. Also, removing the two bumper cover bolts that are under the hood allows you a bit more flexibility to slide the old one out and the new one in under the bumper cover.
Yes I was pleasantly surprised by the quality of the R170 aftermarket grille .............................
My W220 one was a lot of fiddly fettling required to make it a nice "MB worthy" fit :grin:
Cheers Dave
1 - 17 of 17 Posts
