2003 - 2006 SLK 350 Auto Spark plugs !! 12 or 6 ?
198 Views 14 Replies 6 Participants Last post by  frogfoot
Hi again to you all out there. I have been perusing the SLK 350 as a possible step-up from my 2008 SLK 280.
Do all of the SLK 350's have the twelve spark plug technology or do some only use the six plug system that is more conventional ?
What is the cost of a plug change when it comes to changing all 12 and are they a specific plug manufacturers product ?
During the last week or so or so I have also looked at the probability of an SL 350 purely on the basis of it being a considerably more comfortable drive with better shaped seat and backrest profiles (Yes I know that this forum is for SLK's but they do both come as 350's).
Reactions: 1
1 - 15 of 15 Posts
Be glad you do not have the 16 plugs in a 55 :D
anyway... 350s have 6 plugs
  • A 004 159 49 03
    SPARK PLUG
    Code: 716/718/700/830;
    Quantity: 6
  • Haha
Reactions: 2
55
  • A 003 159 97 03
    SPARK PLUG
    [987, 988, 989]
    Quantity: 16
200
  • A 004 159 45 03
    SPARK PLUG
    Code: F204/F203/F209/F211/F171/F906/F212;
    Quantity: 4
spark plug change on a 55 with 16 plugs back in 2013
$444 labor
plugs 16 x $31.50 $504
less discount total $785.80
no dis $948
Thanks Jeff. That is truly mind blowing as well as pocket busting. That is £636.00 Sterling.
Reactions: 1
and spark plugs for Super Charger again in 2016
specific plugs from KLEEMANN. It’s a colder heat range plug. Typical for superchargers
Cooler range of spark plug due to the boost we’re forcing into the motor. Cooler running plugs produce a better spark. 2 heat ranges colder than OE
See less See more
Reactions: 1
Our '55's aren't cheap on maintenance. Looking for rotors (for next summer). JUST for fronts . EACH:
See less See more
  • Wow
Reactions: 1
All you can buy with money is cheap :ROFLMAO:
Reactions: 1
I have come to this conclusion:
See less See more
Sorry to have taken this off topic. Back to:
R171 Spark Plugs (y)
Reactions: 1
I chose TRWs when I changed all four of mine two years ago. They're A LOT cheaper! :)
I drive it quite hard (and over 10k miles) and they look almost brand new. No lipping and I have good grip with my Brembo pads that I got at the same time.
  • Haha
Reactions: 2
bosh plugs on 350 cost me £47 from euro parts and change myself..very easy job to do on it
1 - 15 of 15 Posts
