Ok checked each tire and drv front has 225/55/16 pass front has 205/55/16 left rear 205/55/16 rht rear 225/55/16
Someone rotated tires this way!
Yes, if the left side has the small tires and the right side has the big tires.Would this throw off abs esp bas? Cause a light on dash?
And have you sorted SDS purchase yet ?Also the switches on center console under radio.I believe their skid control and another.They don't work when press the rocker switch..
That's a cool trick 👍 I had to drive 20 Miles to a Star certified smog place and it seemed to shift fine but did go into limp mode 2nd gear one time. I pulled over and shut car off then started it and the rest of trip there and back it was fine..Yup, welcome to california. As long as there is no CEL and as long as the ECU is stock, it doesn't matter what condition the car is, it will pass.
Had to deal with a E46 M3, vehicle did not pass because ECU would not communicate with the smog machine. I unplugged the fuse to the alternator which lighted up the dash with all possible lights (but crucially, not the CEL, given that the alternator was controlled by the cluster and not ECU) and drove to smog shop on battery. It passed. 🤯
See here for part numbers: The web site of slk-linksOk.Ive been trying to find a body molding on driver's front of car between fog light and center lower grill.. first picture is all that I could find
Second pictures is style on my car. It has silver pillar vertical in it..I need the driver's side left side.
