Yes and this place has SDS. So instead of me buying one for 400 to 600 I'll have it done for 150
i hope he does not charge you another 150 after you have fixed the problem and its time to erase the error code. Make a dealYes and this place has SDS. So instead of me buying one for 400 to 600 I'll have it done for 150
If you already replaced it with a cheap one that right there could be the issue.If it's the 722.6 they are relatively cheap..
Errrrrrrrrrrrrrrrrm now I'm curiohsocurios ..............A very reliable source agrees with you Len, 722.618
3rd line up is interesting as well - ME2.0 Y2k 320 🤷♂️Errrrrrrrrrrrrrrrrm now I'm curiohsocurios ..............
I missed that Maestro II ..............ME2.0 Y2k 320
Could be, unless the really early ones had 2.0, could even be a regional thing 🤷♂️I missed that Maestro II ..............
I have R170 Y2k M112 that has ME2.8, I think there may be inaccuracies![]()
Thanks for the info.👍
He just did diagnostics and said it was plate. He said it was a 722.6 and he could change it for 700.00If you already replaced it with a cheap one that right there could be the issue.
However, does the guy who did the diagnostic know that, I mean, AFAIK you have not cleared the previous Codes.
Also, it isn't quite as simple as the Videos appear for an inexperienced DIY'er.
The cheap ones are Chinese junk which have a very high failure rate / don't work outta the box !!
5 speed auto is always 722.6xx
7 speed auto is always 722.9xx
do yourself a favor. get an SDSHe just did diagnostics and said it was plate. He said it was a 722.6 and he could change it for 700.00
He charged me 60.00 just to check.
I told him I'd change it myself.
He said if I send it in to be repaired. I wouldn't have to program it. Only if I purchased a new one.
I think he is right. The 5 speed tranny dont have the TCU embedded inside the transmission. It its in the car, the one practically infested with rats in your case.He just did diagnostics and said it was plate. He said it was a 722.6 and he could change it for 700.00
