Ok found the 2 can wires..up just behind a/c evap box . It will be tricky but I'll get them with solder iron 😁👍
They also say citronela plants drive away mosquitos. Alkaline water prevents cancer etc. Until there is a real unbiased study is done, its all hear say. Well now you know they dont work. Or they dont work well At least.I can't understand why the drier sheets and cayenne doesn't work
Ahh our soap opera has a new twist in the story…..I am at the edge of my seat….Ok found the 2 can wires..up just behind a/c evap box . It will be tricky but I'll get them with solder iron 😁👍
Way ahead of you on looking for second hand SDS..No luck yet..They also say citronela plants drive away mosquitos. Alkaline water prevents cancer etc. Until there is a real unbiased study is done, its all hear say. Well now you know they dont work. Or they dont work well At least.
interestingly, you said the rats came from the previous owner? So did you inadvertently bring home the rats? They might start living in your house. after a while the rats learn to avoid the glue traps too.
I doubt your BAS/EESP gets sorted out even if you find the connection to those 2 CAN lines, the reason is that your BAS/ESP is ALREADY connected to the CAN network. You proved that when you tested continuity in post 450.
there are more chewed up wires Slick. I know its hard to admit. But thats the probability.
It seems you enjoy fixing cars so I dont see why its so bad. Some people spend weeks glueing up toy models and lego sets and after that it just goes on display, they cant even ride that to buy grocery.
If I were you and I was serious about getting the rest of the car fixed, I would start searching for a second hand SDS now.
yep we are at the edge of our seats. maybe you get lucky and BAS/ESP error dissapears!Way ahead of you on looking for second hand SDS..No luck yet..
So I'll solder these can wires and go from there I checkd rest of wiring in foot well. It's good soill take out center console and keep heading towards left of car.. One step at a time. Taking all of dash out will be last resort.
And your right Brian.. Nothing is exact science! 👍
See post #20...encyclopaedia, first post then component locations.Where is PSE mod located in trunk?
found it right under the hydraulic pump for top..Got it thanks..
That's what I needed to know.save your money. Buy an sds. You can sell it for the same price later, maybe even more.
That's a good price.. I'll check it outI’m not an sds expert but this one actually comes with a laptop! Ok laptop isn’t much but over all this doesn’t look that expensive.
It's way overpricedThat's a good price.. I'll check it out
