1 - 20 of 20 Posts
Hi
I have just joined this forum and just recently bought a 2000 SLK 230K.
I am still learning about the vehicle, but have noticed that when you put your foot down ( to the floor) when in 1st gear and sometimes when in 2nd gear, the car seems to lag/hesitate and you have to release the throttle and press more gently to pick up speed
This does not happen when in the later gears. The car is automatic.
Does anyone have any ideas what this might be?
Thanks in advance
Regards
Dan
Dan, going to move your question to the new members introduce yourself section to save you a step, ok?
Thanks Jeff
will take a look through other posts, but if anyone has an answer to my question, please let me know
Hmmm... Wait till some other experts jump in.
My 1st thought would be the MAF sensor. I'd try cleaning it first and see if it makes any changes.
Premium Member 2007 SLK280
A warm welcome from Southern Arizona. Good to have you on board. I'm not familiar with the R170, however, my understanding of the the S and C mode on the R171 is that when in the C mode the vehicle starts off in 2nd gear and has lower shift points. More throttle causes it to downshift into 1st giving you more giddy up and go. Enjoy the people, the forum, and top down cruisin'.
What? Jayson I thought you were an expert!!!
Well this 'expert' (i stayed at a holiday inn express once), says
Techron!!!
http://www.slkworld.com/general-discussion/10172-fuel-additives-engine-tick-knock-sluggishness-hesitation.html
I hadn't come up with this problem so I don't know the exact answer.
But how could I forget about Techron?! Definitely add a bottle in your tank!
In my assumption it can be lack of air in the system, I'd check all the vacuum lines - condition/leaks, etc.
And btw, do you drive in W or S mode???
Welcome and thanks for joining.
Hi, welcome from the North of Scotland. Congratulations on your recently purchased SLK. :)
A quick easy first check. Check the air connections to the supercharger. After I DIY'd my Air Filter I failed to secure the connections and there were air leaks. The supercharger failed to deliver extra power.
Premium Member 2009 SLK55 AMG
Sadly Woolly has passed away
Welcome from NE England. Congratulations on your SLK.
Woolly - Founder & Super Moderator.
Premium Member 1998 SLK230
Welcome aboard,
There is a toggle switch to the left of the gearshift, it should be in "S" summer mode not "W" winter mode.
How well does it accelerate when you have it in "D" & put your foot down?
Discussion Starter #18
Hi to all!
Leapyfish, when i put my foot down in 'D' that is where the lag/stutter happens. When I press the accelerator down, rather than flooring it quickly, but flooring it slowly (if that makes sense) it seems fine
I have contacted a mechanic, who without seeing the car thinks it might be the airmass sensor
Discussion Starter #19
Thought I would give an update
Wednesday evening I went through the 'accelerator reset' procedure I found on the forum. This is where you turn the key 2 positions, put accelerator to floor for 30 seconds, remove key, release throttle and then start. From what I read this is supposed to reset something which stores driving habits.
The problem though still persisted around the 4k rev mark, so after speaking to a mechanic who thought it sounded like the MAF sensor, he was going to come out today to look.
However, today when driving to work the problem seems to have disappeared! Several times when driving slowly, I floored the accelerator to test and on each occasion the car behaved correctly going past 4k revs until it naturally changed. It also behaved at normal cruising speed and then accelerating hard (past 4k revs)
Could this reset I did have worked or will I likely still have the problem again?
you will need to occasionally do the reset. I do it whenever I feel it needs to be 'rejuvenated'!
1 - 20 of 20 Posts
