On my R170 SLK I have a problem with the roof alignment. The front of the roof is perfectly aligned, but on the back side of the roof it missaligns for about 3 mm to the right. This results in a lot of wind noise when I drive over 110 km/h and leakage on the left side of the car. The leakage is dependent on rain intensty and speed, lower speeds give more leakage. I greased all seals with silicone grease (specialy for rubber seals) but that doesn't fix the leakage.
Any suggestions to realign the roof?
only if u update your profile, like this please:
Premium Member 2004 SLK200K
Can you post a photo of the mis-alignment to see exactly which point you are talking about , to make it easier for someone to help ??
