1 - 8 of 8 Posts
Hi
I have a 1999 SLK 230 which seems to have developed an odd whining noise under particular circumstances.
No noise whilst in gear & accelerating, but when i take my foot off the accelerator pedal an odd whining noise can be heard. This happens whilst in gear and whilst out of gear. Hard to pinpoint the exact location of the whine but I believe it is coming from behind.
It also happens whilst driving forward (any gear) and in reverse.
The noise still persists when I've taken it out of gear & rev the engine.
Other than this noise, there appears to be no other symptoms.
Any ideas? My local garage thinks it may be the gearbox but I am not so sure. Thanks for any help you have provide.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
On a smartphone: http://www.slkworld.com/new-members-introduce-yourself-here/330737-how-update-your-profile-post-intro-smartphone.html
What type of transmission do you have? It's difficult to diagnose stuff over the internet but if you could post a clip of the sound (shoot a vid and load it to you tube) it would be helpful.
Premium Member 2014 SLK55 AMG
rear diff.
Drain oil. Refill as specced, make sure you get the right amount in.
It'll probably last longer that you are prepared to put up with the noise and it's barely worth doing anything about as a full diff rebuild or replacement is going to cost 1/2 as much as the car is worth.
Did I ever tell you about the time I had the rear diff of a Land Rover Discovery lock solid at 70mph plus on the A22 just outside Brighton .........
An interesting few seconds! :)
1 - 8 of 8 Posts
