I thought I found an oil leak coming from the front crank seal, I changed out the oil and found that was not it. Looks like the oil pan seal is the only thing left I can see that could be leaking.
Has anyone dropped the oil pan and changed the pan seal on a 1998 SLK230?
Please help
Earl
Premium Member 2002 SLK230K
9 times out of 10 its the crank seal that appears to be coming from the pan seal. The only way to replace the pan seal is to disconnect the motor mounts and jack the engine up.
