1 - 9 of 9 Posts
The driver's manual says that there is a 12 volt plug on the passenger's side just above the little cargo net. Do you have it? Is it sort of hidden?
D
Guest
Yeah its on mine and totally exposed well it has a cover but its all marked up and impossible to miss
Sadly Woolly has passed away
I might be wrong, but if you have an ashtray and lighter in the centre console, then you don't get the footwell 12v outlet. As Dan says, you can't miss it if it's fitted.
I have an ashtray as well as a lighter in the center console, and I also have a footwell 12v outlet.
Not sure in which option combo you get it but if you have it, you can't miss it! :tazz:
Corkscrew,
the 12-V-plug is exactly at that position in my car which you have described. But there might be a correlation concerning national options.
Same here.
Corkscrew,
I have a 12 volt gig-like socket in the boot of the SL but nothing on the passenger's side of the SLK. There is a small plastic plate there that probably covers the hole.
1 - 9 of 9 Posts
