1 - 9 of 9 Posts
Hi
I seen a private reg. on ebay. I'm in a dilemma To Buy or Not Buy that is the Question?
Do I upgrade my car or take the cheaper option to stick a dateless private registration on my car. Can't afford the latest shape yet thou!
Any advise.........:confused:
aka John
Well, you seem to be right around the corner from the seller - are you seriously asking if you should spend £3,999.00 on a private reg or if you should keep whatever you have and put that plate on it?! :)
I can sure think of better things to bolt onto my R171 than an over valued private plate - but that's just me. I guess one could look at it as an investment, since the last time it traded it sold for a mere £1900.
Thanks that is an option.
My mates has a low digit dateless plate on his car & makes the car look more expensive, prestige & looks better than standard plates.
Don - Founding Member #4
:td:Car yes, if feasible. Plate no.
:confused:A low digit "dateless" plate or neat personalized plate might be eye catching and possibly envious. More important things in life.
Just too expensive for 4K British Pounds.
Kank,
Thank you,
Founding Member #12/Moderator
1 - 9 of 9 Posts
