1 - 10 of 10 Posts
I'm in desperate need to find an OEM Coolant Reservoir Tank for my SLK320 and I cannot find it anywhere! Could anyone point me to the right place? The best I've found was a part on ebay that someone just yanked out of an old SLK and I'm not sure if that's the most reliable source.
Super Moderator
Welcome from New Hampshire. Have you tried your local junk yards? There's a guy parting out his 230 if i can find the link i'll post it for you.
Troy,
Thank you,
Founding Member #12/Moderator
Thank you Wolly, for putting my post in the appropriate section.
Livefreeordie, thank you for checking it out of me. That was really nice of you.
jbanks. I really appreciate it, I will make sure to do just that. Thanks for showing me the ropes!
New parts?
Thanks for all the help but i am really tryin to find a place I can buy brand new parts anyone know where i can do that?
I understand. New parts for a car that is two generations behind may be a challenge. Here are some recommendations.
http://www.bimmerspecialist.com/usa/parts/index/mercedes
http://mercedesbenzgenuinep1.reachlocal.net/partlocator/index.cfm?action=getJointLocator&siteid=214269&chapter=&Sectionids=8,0&groupid=61534&subgroupid=0&componentid=0&make=67&model=SLK Class&year=2004&graphicID=F344030&callout=2&catalogid=1&displayCatalogid=0
http://genuinemercedesparts.com/partlocator/index.cfm?action=getJointLocator&siteid=215306&chapter=&Sectionids=0,2308&groupid=51823&subgroupid=12132&componentid=0&make=67&model=SLK Class&year=2004&graphicID=5766093&callout=18&catalogid=2&displayCatalogid=0
Here is a place I found that parts out old wrecked cars that I'm keeping for further use. Just an FYI.
http://www.weberbrothersauto.com/Default.aspx
Best Wishes in finding your part.
1 - 10 of 10 Posts
