AMG DRL retrofit coding - Mercedes Benz SLK Forum
Star Diagnose Vediamo Coding Any links or post’s leading to pirated software will be immediately deleted. SLKWORLD is not responsible for any damage caused by miscoding, use at your own risk.
  • 1 Post By VII7
#1 Old 04-30-2019
Quoted: 108 Post(s)
I have managed to get my hands on a VAS PassThru device, and successfully establish (and ECU code) using Vediamo.
I have now also finished mounting the AMG DRLs, but they need to be programmed. (Original DRL is 15W/12V, while the AMG DRL is 5W/12V).
The lamp is not lighting up during daylight, and I'm thinking there should be a parameter somewhere, in Vediamo.
Have been checking in the IC172 and HLC166 file descriptor parameters, but could not find it (perhaps I might have missed it).
I have been reading similar posts, with similar behaviors, but they solved it by adding P30 option to Vedoc, then SCN coding it, at the dealership (something I would like to avoid doing (don't want options on my car, that do not belong on my car).
So can somebody offer more details regarding this? Maybe a different file descriptor? Or maybe I missed the right parameter?
Wilhelm Sorban is offline
#2 Old 04-30-2019
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 162 Post(s)
You need to look in the front SAM.
Also note adding P30 to Vedoc does not seem to be related to the DRL type.
VII7 is offline
#3 Old 04-30-2019
Quoted: 108 Post(s)
Thanks.
Indeed, I should have probably mentioned option code 772 (though I do have that option, somehow EPC knows that my car is not fitted with the AMG LED lamps that also have the code 772).
In any case, I have tried to connect to the front SAM, using a file descriptor from 2013, and another from 2015.
Since I have recently had some SCN coding on the SAM, maybe a newer version was coded into it, and these descriptors are obsolete?
Do you happen to have a more recent front SAM descriptor that you could send me?
#4 Old 04-30-2019
Other Toys: CLS63
Quoted: 162 Post(s)
Connect with xentry and check the version, I'll check if I have a descriptor for it (note my library is not cutting edge).
Also are you using the correct baud rate?
VII7 is offline
#5 Old 04-30-2019
Quoted: 108 Post(s)
The only laptop that I found VAS to work was on my brother's laptop. I will have to check the version tomorrow.
As for the baud rate, does tha front SAM use a different baud rate than say the IC?
I managed to flash the IC (remove the gasoline warning, as per your guide), managed to connect to the headlight controller, but for the SAM, I am unable to connect.
If I use the 2013 descriptor, I get an Unknown error, and if I use the 2015 one, I get a time out.
#6 Old 05-01-2019
Quoted: 108 Post(s)
And here is the version of the Front sam:
#7 Old 05-01-2019
Other Toys: CLS63
Quoted: 162 Post(s)
Yes descriptors can include multiple baud rates, only one will work on the vehicle.
VII7 is offline
#8 Old 05-01-2019
Quoted: 108 Post(s)
Wow the synchronization )
How can I find out the required baud rate of the front sam?
#9 Old 05-01-2019
Other Toys: CLS63
Quoted: 162 Post(s)
Just try them out one by one.
VII7 is offline
#10 Old 05-01-2019
Other Toys: CLS63
Quoted: 162 Post(s)
Your SAMF descriptor should have the variant MOPF_204_2ndBugfix
It was already available by 14.11.2012.
VII7 is offline
#11 Old 05-01-2019
Quoted: 108 Post(s)
Is there a specific place where you can find out the version date? How could you tell?
#12 Old 05-01-2019
Other Toys: CLS63
Quoted: 162 Post(s)
Descriptors are dated, it's on the properties/notes.
VII7 is offline
#13 Old 05-01-2019
Quoted: 108 Post(s)
I mean the variant code: MOPF_204_2ndBugfix
How can you tell it was available by 14.11.2012 ?
#14 Old 05-01-2019
Other Toys: CLS63
Quoted: 162 Post(s)
Yes, because a descriptor I have with that date has that variant.
VII7 is offline
#15 Old 05-08-2019
Quoted: 108 Post(s)
I have successfully programmed the front SAM with the following:
- 100% light intensity during daylight
- 50% light intensity during night time
Then I noticed that these changes would take effect, but then, upon restarting the vehicle, the settings would be reset.
So I found out that the front SAM has a non-volatile memory, where the settings need to be persisted.
Therefore, in Vediamo, under ECU/SAMF/Downloads (folder) I had to execute the EEPROM-Schreiben functionality.
Select the Parameter-schreiben in the dialog that opens, and click ok.
Afterwards, in the Functions folder, I executed the Hard Reset function.
Now, every time I restart the vehicle, my settings are no longer lost
#16 Old 05-08-2019
Other Toys: CLS63
Quoted: 162 Post(s)
Ah glad to see you've figured it out, this will be a good reference for others
(I myself might do this if I find some decently priced used LEDs).
Wilhelm Sorban likes this.
VII7 is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R172 SLK Class Cars > Star Diagnose Vediamo Coding
Humble beginnings to performance powerhouse - Mercedes-Benz celebrates 25 years of its C36 AMG Berliner Heckflosse Off Topic 0 09-13-2018 12:43 PM
The Mercedes C36 AMG Is An Incredibly Affordable Classic That Needs To Be On Your Radar Berliner Heckflosse Off Topic 2 08-08-2016 07:50 AM
Slk63 amg ???? NTT AMGs 3 09-29-2013 03:17 PM
SLK 171 350 by Tzitzos tzitzos General Modifications R171 86 11-02-2012 06:34 PM
MB Official Release of 2009 SLK Cold Shot SLK R171 General Discussion 208 10-13-2008 02:35 PM
